12-25-2018 19:59
12-25-2018 19:59
Fitbit ace won’t connect to iPhone after asking for the 4 digit number.
02-03-2019 00:49
02-03-2019 00:49
12-26-2018 02:23
12-26-2018 02:23
Having the same problem here and have deleted and re-installed app several times, disconnected my Versa and reset the Ace. Hopefully someone will have a solution.
12-26-2018 09:47
12-26-2018 09:47
Same issue. Getting a 500 server error after entering the code.
ERROR
The operation couldn't be completed.
(com.fitbit.HTTP error 500.)
Best Answer12-27-2018 06:36
12-27-2018 06:36
@Kateruss44 Welcome to our Fitbit Community and it's great to see you here @MabelDoodle @rpcunningham! I'm sorry about the difficulties you've experienced with your Ace trackers.
I'd like you to restart your devices as described in this help article. Once you guys have restarted your Fitbit trackers, please try the setup process one more time and let me know how it goes.
Keep me posted! ![]()
Best Answer12-27-2018 06:48
12-27-2018 06:48
Consolidating posts to this thread:
Best Answer12-27-2018 09:13
12-27-2018 09:13
Hi Juan
I have reset the Ace, switched the bluetooth off and on from the iPod (have also tried to set it up from my iPhone and get the same message) and am getting the message "There was a problem communicating with your tracker. Please try again" each time I input the 4 digit number. I am going to exchange the Ace - it's v disappointing.
Best Answer02-02-2019 16:59
02-02-2019 16:59
I am having the same issue with my sons Ace. Only got it today this is driving me crazy. Nothing that I have done has changed the outcome. Did you get this resolved ?
Best Answer02-02-2019 18:03
02-02-2019 18:03
Best Answer02-03-2019 00:49
02-03-2019 00:49
02-03-2019 01:18
02-03-2019 01:18
Best Answer02-03-2019 01:39
02-03-2019 01:39
Best Answer02-03-2019 01:46
02-03-2019 01:46
Best Answer02-06-2019 07:48
02-06-2019 07:48
@MabelDoodle Thank you for for sharing your feedback. I would like to follow up and would like to know if the issue persists or if your daughter's Ace could be set up.
@Paulawoolfy I'd also want to follow up with the issue that you are experiencing with your Fitbit Ace. I was able to get in touch with our Support team and was told that you had a conversation via chat. Was a solution provided?
See you guys later! ![]()
Best Answer02-12-2019 12:34
02-12-2019 12:34
Hi
purchased an ace today but can’t get it connecting any advice,
have reset the ace, reinstalled the app and keep getting same error code
so frustrating
Best Answer02-12-2019 13:02
02-12-2019 13:02
02-13-2019 07:52
02-13-2019 07:52
@GillMStew Thank you for joining us in this thread and our Fitbit Community! I'm sorry to hear that your Ace is not connecting with your phone. Thank you by the way, for troubleshooting this issue before contacting our forums. In order to assist you accordingly, please let me know what is the phone model that you are using to set up your Fitbit Ace.
@MabelDoodle Thank you so much for sharing your feedback and advice. I'm glad to hear that your new Ace is working properly.
See you guys around! ![]()
Best Answer02-13-2019 12:20
02-13-2019 12:20
I'm having the same issues. The Fitbit was purchased on Tuesday. It connected fine but then connected an Alta for my elder son after it was given to him and tried to connect the Ace to a new profile for my youngest and won't connect now. I turned off Bluetooth, reset the ace and even deleted fit bit and made a new account and it gets to the code and says connecting then nothing shows up in the profile. Please help
Best Answer02-13-2019 13:14
02-13-2019 13:14
Best Answer02-13-2019 13:51
02-13-2019 13:51
Thanks. I've deleted that account and will try resetting the band again when I get home and hopefully that works
Best Answer02-13-2019 14:35
02-13-2019 14:35
