07-28-2021
10:37
13:57
AndreaFitbit
07-28-2021
10:37
13:57
AndreaFitbit
Can you advice, how do I sync my Ace on the web based dashboard? In the website, there is only text "No devices paired". But how do I paire that device?
Welcome to the Fitbit Community @Tyllerö. Thank you for sharing your Ace sync inquiry.
Connect Ace to an iPhone, iPad, or Android phone to transfer (or sync) data to the Fitbit app, where you and your child can see their stats in kid view, participate in challenges, and more. To verify that your device is compatible with the Fitbit app, go to fitbit.com/devices. You won´t be able to connect with a computer.
If your child or children don’t have their own device, you can sync their trackers with your device. Note that if you have multiple trackers connected to the same device, you must sync each tracker individually.
To begin, create a Fitbit child account for each child and follow the on-screen instructions to connect the trackers to your device. For instructions, see How do I set up Ace for my child?
After you connect the trackers, follow the steps below to sync each tracker:
I hope this information helps.
