01-04-2021 18:12
01-04-2021 18:12
I have logged almost 70,000 steps today that is not correct is there something wrong
01-06-2021 14:31
01-06-2021 14:31
Hi @crich, let me give you a warm welcome to our Community!
If that amount of steps are reflected on your Alta, I suggest to sync your device and check if it appears on your stats. If your Alta isn't syncing you can follow the steps in this link Why won't my Fitbit device sync?.
Keep in mind that if you have other devices paired or MobileTrack, the steps tracked by them are also reflected on your app.
I’ll be around if you need anything else.
