05-11-2016
12:56
18:17
05-11-2016
12:56
18:17
Has anyone had issues with their DONGLE? Each time that I have gone to sync my Alta on my computer I get the "Connect Dongle" message. But I leave my dongle connected to my computer. Once I've removed and replaced it I have no problem syncing.
Could this be an issue with a dongle with too loose a connection? Or do I need a replacement?
05-11-2016 15:34
05-11-2016 15:34
@WisdomSeeker wrote:Has anyone had issues with their DONGLE? Each time that I have gone to sync my Alta on my computer I get the "Connect Dongle" message. But I leave my dongle connected to my computer. Once I've removed and replaced it I have no problem syncing.
It sounds like the program waits to see the new connection before proceeding, not necessarily that something is broken.
...my $.02.
Best Answer05-11-2016 15:34
05-11-2016 15:34
Could also be the USB Port. Try switching it to another.
If it does not help contact support
Im sure they will take care of you!
Wendy | CA | Moto G6 Android
01-05-2020 09:03
01-05-2020 09:03
mine does the same thing, but when I take it out, and put it back in, it still says 'dongle not connected can't sync'.
Best Answer01-06-2020 10:38
01-06-2020 10:38
What kind of a link is that? No one there to answer anything.
