10-29-2021
11:49
03:07
10-29-2021
11:49
03:07
Battery has recently started only charging to 80% but used to go to 100% . Now only lasts a few days rather than a couple of weeks, not the only one this happened to in my group either, who are all experiencing same issue! Anyone else?!
11-12-2021 03:12 - edited 09-02-2023 07:44
Hi there, @John1603. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Alta HR. I understand where your concern is coming from.
Have you tried restarting your Fitbit device as suggested by @NellyG?
If you still need help, I recommend following the tips and recommendations provided in this help article Why isn't my Fitbit device's battery charging?
If the battery still draining after all, take into consideration these factors.
Best Answer10-31-2021 02:16
10-31-2021 02:16
Hi @John1603 Have you tried restarting your Alta HR a few times? If you haven't, give it a try and then charge it again. 8f it still wont charge beyond 80% then 8t is sadly dying.
Helen | Western Australia
Best Answer11-12-2021 03:12 - edited 09-02-2023 07:44
