07-04-2022 13:12
07-04-2022 13:12
what other fitbit products have the features AND simplicity of the AltaHR
07-06-2022 14:34
07-06-2022 14:34
@marie-teresa I upgraded from the Alta HR to the Inspire 2 about a year and a half ago. I really like the Inspire 2. It does have a few more features, but some of them are really useful and they aren't that hard to learn.
Also, I found the Inspire 2 a lot more comfortable for sleeping. The back is more rounded. It doesn't have the kind of edges that the Alta has.
07-05-2022 06:18
07-05-2022 06:18
Hi, @marie-teresa , the closest Fitbit to the Alta HR is the Inspire 2. The Inspire HR would also be possible, but you may struggle to find a new one, and if buying used it is difficult to know how well the battery has been treated, which will make a big difference to how long it lasts. The Inspire 2 is a real favourite of mine, and I actually prefer it to the Alta HR - for one thing there are many more.
An alternative might be the Luxe. It is a really delicate, petite Fitbit with no buttons and a swipe only screen and somewhat simpler than the Inspire 2. The screen is colour so nicely visible even in the sunniest weather.
If you go to the Fitbit Store you can do a “compare tracker” to see which one might suit you best. Good luck, and let us know what you decide. Welcome to the forums!
07-05-2022 08:03
07-05-2022 08:03
07-06-2022 14:34
07-06-2022 14:34
07-06-2022 16:52
