10-13-2019
11:40
20:08
10-13-2019
11:40
20:08
My Fitbit Alta HR just started today not syncing. So I did update, still cannot find my device. (Android ZTE) last sync was last night at 5:32pm ct US so this is a new thing as of this morning. Anyone have any idea how to help or fix?
10-13-2019 12:02
10-13-2019 12:02
Hello @EvaMGillespie Welcome
I see your having syncing issues. I hope I can help.
1. Log out of the Fitbit app and force shut the app by swiping up
2. completely uninstall the Fitbit App from your device
3. now completely shut down your device and wait about 1 min then restart your device
4. once your device has reloaded reinstall the Fitbit app by downloading it from the App Store
5. once it’s installed, log into your device as you normally would with username and password
6. don’t touch anything in the app...just wait until you get a prompt from your Bluetooth.
7. When prompted by your Bluetooth tap yes
8. now try to sync
😃 please let me know if my suggestions resolved your issues. If my suggestions did indeed resolve your issues would you please tap “best answer” under my post with the instructions/suggestions that helped. This helps others who come here to find answers similar to your issue. Thank you.
Best Answer10-13-2019 12:02
10-13-2019 12:02
8. now try to sync
Best Answer10-19-2019 15:59
10-19-2019 15:59
Hello again @EvaMGillespie
I wanted to check back in with you to see if my suggestions did indeed help your syncing issues. If indeed I was able to help would you please tap the “best answer” box under my post containing my suggestion to you? It really helps others who come to this community looking for answers to questions similar to yours. I’d really appreciate it. 😃
Best Answer03-18-2020 18:11
03-18-2020 18:11
I tried this and it didn't help.
Best Answer03-19-2020 15:52
03-19-2020 15:52
I have tried all of the above. It has not synced properly since Sat,3/14 (it is now 3/19)
