Alta HR screen blank
My Fitbit plugs into the charging cable, makes a buzzing noise but doesn't display anything. It can synch to my Android phone with no problems. If I have to replace it, are there any specials discounts or available? Thanks in advance .
1 REPLY 1
Welcome to the Community, @Jolies75.
I would like to know if you keep having problems with your tracker's display? If so, I recommend restarting the unit by following the steps in the article: How do I restart my Fitbit device?.
Now about your warranty inquiry, you can check our warranty policy here.
Let me know the outcome.
