06-12-2022
17:58
07:16
06-12-2022
17:58
07:16
I can hardly see the time. Screen is so dim. It's fully charged. What can I do? Getting worse!
06-12-2022 21:13
06-12-2022 21:13
Hi @Bshelly over time, the Alta HR screen does get more dim. Mine did the same thing and it was past warranty, so I got the Luxe. If you're still under warranty, you should get with support about any options that may be available. Just so you know, the Luxe has a much brighter screen, even in direct sunlight.
