04-20-2017
10:05
10:28
04-20-2017
10:05
10:28
Welcom to the Community Forums @Ceplarson! Good to see you around. 🙂
I would say, you can try to restart your Alta HR and see if this helps. For that, follow these instructions:
If that doesn't work, leave your Alta to have the battery drained and when you put it to charge again, see if it has stopped vibrating.
Let me know how it goes!
10:56
10:28
04-20-2017
10:56
10:28
Oh, I see... Thanks for getting back and letting me know @Ceplarson! 🙂
I'm happy to hear that they're getting you back on track. Let me know if you need anything else!
Best AnswerHello,
I have the same problem, my Alta HR constantly vibrating till ruined down.
I tried the suggested procedure below.
After restarting the vibration has stopped and the charging has been started.
When it recharged completely and removed from the cable it died - no display no respond anymore.
Please advice.
Best AnswerTry several restarts once again. If it is still having problems then yoj will need t contact Support (link in my signature )
Helen | Western Australia
Thanks Nelly, I have tried 5 times, but no success
Best AnswerOk, Support is your next step.
Best AnswerHello, I have the same issue and no joy restarting 😞 Can't move off off batt % charged screen.
Best AnswerI'm having the same issue. Tried all of the troubleshooting steps such as rebooting, letting the battery drain, etc. Nothing is working.
Can someone from support contact me at luvtommie@hotmail.com?
Best AnswerI'm having the same problem & have restarted a few times. This started happening 2 days after I noticed my fitbit just randomly dying & after resets on both days.
Best AnswerHello there,
I also have this problem now and tried the reset method multiple times, but not successful. It continues to vibrate when I plug it in after the battery dies.
What should I do/try next? Thank you so much for your help!
Best AnswerHi Ferdinand,
I tried the steps you outlined and my Fitbit is still vibrating. When charging it vibrates and shows a battery sign with a warning.
Do you have any other fixes?
Thanks,
Edwin
Best AnswerWhat button on charging cable ???
