12-26-2022
13:18
03:20
12-26-2022
13:18
03:20
I recently got a FitBit Alta HR, I already set it up with the Fitbit app but seems to be stuck displaying the "www.fitbit.com/setup" and I haven't been able to see in the display the clock. Eveything else is working fine (sensors and all), that's the only problem.
Any idea how I can see the clock on the display instead of the setup message?
12-27-2022 03:21
12-27-2022 03:21
Hi there, @SoyAleJimenez. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Alta HR.
Please try the following steps:
If you can't get started with your Alta HR, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Best Answer12-27-2022 03:21
12-27-2022 03:21
Hope that helps.
Best Answer02-15-2023 17:06
02-15-2023 17:06
I couldn't see the answer for your,problem not being able to see my clock. It's still stuck on www.fitbit.com/setup
Best Answer02-16-2023 04:12 - edited 07-12-2023 05:33
Hi there, @Bminor. Welcome to the Community Forums.
To better assist you, would you mind confirming that you've followed the steps I provided here?
Best Answer07-10-2023 09:03
07-10-2023 09:03
I have tried your suggestions includiñg the hard reboot and I still only have the Fitbit web address on the display. Any other ideas? Thanks.
07-11-2023 06:48
07-11-2023 06:48
Hello
I Have the same problem and they dont respond
Only Stuck in the setup screen , already did the steps above but nothing wait for an answer
07-13-2023 12:33
07-13-2023 12:33
Same problem bought a replacement brand new cannot use it. Who decides the best answer??? when the answer doesn't even work?
