12-22-2022
02:00
16:54
12-22-2022
02:00
16:54
It seems like the battery of Alta HR has 3~5years lifespan. And I wonder if I can change the battery of Alta HR or not?? Because most answers about Dying Alta HR are getting new device.
So...it means once the battery dies, I cannot get the new battery? but I need to get new one?
When I think about a mobile battery(iPhone or iPad...etc.), when the battery dies, I can change the battery. So I am curious that Fitbit products allow to change the battery or not?
Thanks!!
12-22-2022 02:23
12-22-2022 02:23
Hi @Lucy4499 Unfortunately small devices like Fitbits do not usually have replaceable batteries. So once your battery dies on a fitbit then you need to buy a new tracker.
Helen | Western Australia
12-22-2022 02:23
12-22-2022 02:23
12-22-2022 03:17
12-22-2022 03:17
Thank YOU NellyG for your answer. It helps me out~ I was about to goolge for the replaceable battery of Alta HR. So you save my time lots...Thank YOU !!!!
