07-27-2020
11:56
19:01
07-27-2020
11:56
19:01
I am having a hard time finding alta hr to replace mine that died.is it discontinued? What is comparable?
07-27-2020 12:47
07-27-2020 12:47
The Alta HR has been discontinued. The Inspire HR would be considered its replacement. It's about the same size, and I think it has all the capabilities of the Alta HR, with the addition of the Exercise App which lets you select which type workout you are doing and tell when you start and end, instead of having to rely on auto-recognition.
Best Answer07-27-2020 12:47
07-27-2020 12:47
Best Answer07-27-2020 13:07
07-27-2020 13:07
Excellent, thank you so much for your quick reply and info!
