07-29-2020
17:09
19:01
07-29-2020
17:09
19:01
Only 12 months old roughly, but now the battery will only last a day or two (not even one yesterday). And it won't sync anymore but I can't figure out why. I can't get through to Fitbit due to the covid limitations
@BigBethFit Have you tried pairing in a location in your home away from other Bluetooth devices?
sometimes other Bluetooth devices cause disruption.
Hi @BigBethFit
Please restart your fitbit at least three times and restart your phone.
Also clean the charging contacts and make sure your fitbit is charging fully 100%.
I also don't charge my fitbit till the battery dies (but that's just me) - I find that it elongates the battery life of a device (it's something i've always done with my electronic devices).
To add, you can also turn off all day sync and notifications to see if that helps with the battery life.
To Restart the Alta HR:
Please let us know if this was helpful.
Best AnswerI tried thanks, unfortunately it didn't help. My friend said try delete device and then re add it. So I did but it says found device I put the number in but it says pairing failed! And it won't pair no matter what I do. Soo frustrating ☹️
Best AnswerYes I have. I have only got 2 other device both off (headphones and a speaker) I have even tried at other places. It's only 12 and a half months old. I expected it to last longer.. but nothing helps ,😥
