07-10-2020
06:23
17:22
AlejandraFitbit
07-10-2020
06:23
17:22
AlejandraFitbit
I just got a new Alta to replace my old one. I removed the old one and have been trying to set up the new one. I follow the directions in my app and it locates my Alta but when I enter the 4 digit code, it won't connect.
It's comes back with a "There's a problem communicating with your tracker. Please try again." I've followed the suggestions: make sure tracker is charged (yes), Make sure Alta is nearby (Yes) and Turn off Bluetooth and turn it on again (Yes). Any other suggestions before I send it back?
Welcome to the Community, @Pasjes2.
Thanks for troubleshooting this setup issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else.
