06-02-2020
01:41
14:05
AlejandraFitbit
06-02-2020
01:41
14:05
AlejandraFitbit
Hi, hope someone can help 🙂
A few times now, my Fitbit Alta won't fully charge. It charges till about 75%. Also, in the Settings, I have it switched off that the battery level is showing. However, with the 75% charge, the first thing my screen shows when I tap it, is the battery level. Anyone an idea on what's going on?
Thanks for help in advance.
01-27-2021
14:06
04:53
01-27-2021
14:06
04:53
It's great to see you around, @StephanieVerena.
I appreciate all the efforts in trying to fix this battery issue. If you are having problems charging your tracker, I recommend taking a look at the help article: Why isn't my Fitbit device's battery charging? and follow the instructions provided there.
Let me know the outcome.
Best AnswerThe problem isn't that the fitbit doesn't charge, it just doesn't fully charge.
