08-16-2020 03:51 - last edited on 01-06-2021 19:20 by LiliyaFitbit
My fitbit alta is burning off calories even when i am not wearing it. How can I fix this?
08-16-2020 04:20
08-16-2020 04:20
That's quite normal and it's working fine.
As well as tracking calories burned through activity your fitbit also tracks your BMR calories. These are the calories you burn just keeping your body alive (even when asleep). They are calculated from your profile settings for age, height, weight etc so you needn't be wearing your fitbit to get them.
Best Answer08-16-2020 04:20
08-16-2020 04:20
Best Answer11-20-2020 11:07
11-20-2020 11:07
Is there anyway to delete this? I’m finding it’s interfering with my calorie counting
Best Answer11-21-2020 00:05
11-21-2020 00:05
@chloebrookesss there isn't a way to stop BMR calories being counted I'm afraid. But when counting calories as part of a weight management plan then you need to include them - you really do burn those calories.
Best Answer11-22-2020 09:16
11-22-2020 09:16
You are burning these calories! If you turned this feature off, your app wouldn't be tracking all the calories that you lose and your calorie-counting would actually be less accurate!
Best Answer11-22-2020 10:01
11-22-2020 10:01
