12-14-2020 19:37
12-14-2020 19:37
How do you withdraw from a community?
12-14-2020 19:49
12-14-2020 19:49
Hi @Ritalu if you joined a group on the app, click on it and then pull down on the upper right hand to leave the group. Was that what you needed?
Best Answer12-15-2020 05:30
12-15-2020 05:30
Best Answer12-15-2020 08:34
12-15-2020 08:34
@Ritalu with my Android app, I go to Community and select Groups (from the top of the page), then click on the group I want. Upper right there are three dots where I click and it gives me the option to leave the group.
Best Answer12-15-2020 10:41
12-15-2020 10:41
Best Answer12-15-2020 10:50
12-15-2020 10:50
If you don't see the group, is it possible the group is no longer active?
Best Answer12-15-2020 10:56
12-15-2020 10:56
Best Answer12-15-2020 11:02
12-15-2020 11:02
You want to leave that group? It should show up under your groups.
