02-19-2020
10:46
19:45
02-19-2020
10:46
19:45
Hello. My display screen is not working. I did the reset and it worked for about 2 minutes and then stopped again. When I attach it to the charger the Fitbit logo will pop up but the time, steps, etc will not. Before I did the reset a few minutes ago it said my battery was at 90%, now on the Fitbit itself it says 25% but my phone app says 90%. Hope this info helps to figure out the issue.
02-19-2020 10:48
02-19-2020 10:48
Since hitting post the other stats are popping up now that it has been plugged in for a few minutes. Seems like my battery is draining very quickly
Best Answer02-21-2020 20:51
02-21-2020 20:51
Hi @BMcAfee Try restarting your tracker several times and see if it then performs better. If it doesnt then I suggest you contact Support.
Helen | Western Australia
