05-31-2020
14:59
19:19
05-31-2020
14:59
19:19
I have an alta HR and recently none of my exercises - walk and/or jog - are tracking. However, elliptical keeps showing up randomly - sometimes an elliptical instead of my 1 hour walk or sometimes an elliptical while doing nothing. Any advice? I can manually log my exercise but would like to get the auto recognition working again.
Can only suggest you check the exercise section on phone and see if you need to reset some of the areas so this info will show. It is a trial and era process seemingly.
I am wanting to change paces to calories and distance to minutes. Confusing. I have attempted numerous avenues - no success.
Best AnswerI have an Alta which tracked my walks with minutes and calories, but suddenly is now tracking data with distance and paces. I want to go back to the minutes and calories - have tried numerous things. The only thing I can determine is once I won the "sneaker" it seems this started happening. Bah ! Pls let me know if you have any suggestion how to get the minutes and calories back.
Thank you kindly !
Best Answer@882alex I've moved your Alta HR question to the correct board.
My first suggestion would be to tap the settings on the page listing of your exercises and disable any exercise you do not do.
@map2442 may I ask how you are tracking your exercises? Are you using the Fitbit App?
I only ask because the Alta only has auto detect of exercises and distance will not be displayed?
There are various screen on the report for the exercise, have you looked at them all?
