Randomly my fitbit Alta screen goes blank, the battery is no where near flat more than 50 %.
Plugging in to it's charger restores the screen immediately, the fitbit logo is shown first.
Thanks.
Hello @Jmu2 It's great to see you again in the Community Forums!. Thanks for the troubleshooting you tried prior to posting.
Can you please let me know when did the issue start? Have you noticed if it only happens when your Alta is at 50% of battery life?. Has your Alta been in touch with water or sweat? I recommend cleaning your Fitbit device after being exposed to water or sweat. For instructions, please check:
How do I clean my Fitbit device?
Let me know how it goes.
Best AnswerHi
It first happened just once last summer and then more frequently in the autumn.
The battery can be more than 50% , my fitbit is clean and dry.
It seems to help if I give my fitbit a quick charge every morning, I would prefer to charge it more fully and completely; the last time I did this in the evening it crashed the following morning despite being almost fully charged.
Thanks for your advice.
Hello @Jmu2. It's nice to see you again!. Thank you for the information.
I’ve created a support case for our support team to help you out. You should receive an email soon. Note that we may take a bit long to get back to you due to recent events affecting our operations.
See you around.
