01-04-2021 07:11
01-04-2021 07:11
My Fitbit's display is too dark to read. I've tried resetting the device as instructed. No change.
Help.
01-04-2021 08:14
01-04-2021 08:14
@BACrutcher - I’m sorry to say the Alta is quite an old Fitbit device. It may be time to consider a new one. If you like the smaller tracker, you may want to look at the new Inspire 2. Wish I had better news for you.
Best Answer01-06-2021 04:54
01-06-2021 04:54
Hello @BACrutcher Welcome to the Community Forums!. @SunsetRunner Thank you for the input!.
@BACrutcher thanks for resetting your Alta. Did you restart it by following the instructions here? Sounds weird that your Alta's display is dim. I would like to know if this issue affects the display all the time or if the display is dim when you are outside when the sunlight hits your tracker.
I look forward to your reply.
