08-03-2017
20:49
18:17
08-03-2017
20:49
18:17
After firmware update, it worked fine. However, an hour later, fitbit.com/setup message appeared on my fitbit display. I tried to go through the set up again, but bluetooth wouldn't recognize my fitbit. I tried to reset several times, no luck. Please advise. Thank you!
08-05-2017 06:38
08-05-2017 06:38
It's great to see you around @ElizaH @JeannineAG!
I totally agree with @JeannineAG perform the restart 2 or 3 consecutive times and keep an eye on it. If the issue persists try the setup process again, check out the instructions for the different platforms below:
Hope it helps!
08-03-2017 23:11
08-03-2017 23:11
Don't remember the actual setup anymore. But mine did this a few times and I reset by holding down the button for 3 seconds and then 1 more hold. I absolutely THINK this might work. Good Luck! ❤️
Best Answer08-04-2017 13:24
08-04-2017 13:24
Thank you Jeannine, will try to do this again tonight. I did reset (holding down the button) several times, but no luck!!!![]()
Best Answer08-05-2017 06:38
08-05-2017 06:38
Hope it helps!
08-05-2017 22:15
08-05-2017 22:15
Thank you so much for your support! It worked!! Will see how long this will last. Hope your weekend is well!
08-09-2017 07:35
05-29-2020 06:05
05-29-2020 06:05
same issue here, After the firmware update, my fitbit versa's screen shop showing content, but it is still tracking my heartrate, steps, etc. I did try restarting versa but no luck.
