02-12-2020
03:19
19:45
02-12-2020
03:19
19:45
I have been frustrated that more often than not, my sleep data is split into two events, usually before and after my usual trip to the bathroom in middle of the night. It’s been a pain, but in the past I’ve been able to edit and correct the better record and delete the other one. This morning it will only let me edit my goals, not my actual sleep and wake times. Isn’t that available anymore? Also, is there an easier way to combine them or to stop it from splitting the record? I’m not really awake for that long, so not sure why it’s happening. Thanks!
02-16-2020
16:57
07:08
02-16-2020
16:57
07:08
Hi @JRaeH, welcome to the Community Forums!
Thanks for bringing this to my attention and the details that were shared in your post, I totally understand how frustrating this matter can be for you. To better assist you with this, can you please let me know when was the first time you experienced this issue and how many times since then? If you haven't already done so, I recommend you to restart your Alta HR and try wearing it on your non-dominant hand when you're going to sleep. Also, to edit the sleep information you can check our help article: How do I add, edit, or delete Fitbit data and activities? but keep in mind that the actual Sleep Stages cannot be modified.
Let me know if you have any additional questions.
