My battery level
When I had to reset my Alta HR - my battery level icon disappeared - How do I get it back
1 REPLY 1
Hi @Holliday074,
I think you may need to check your app to see if you have the battery level indicator checked to display on your device.  If you do, then just sync the device and it should reappear.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
