08-05-2020
10:56
19:01
08-05-2020
10:56
19:01
I wish to keep my old alpha HR as a back up due to cracked screen.
Can I get the new one to keep the old data. Do I wait until the battery goes flat or turn off if I can work out how?
How do I get it to track via GPS or does this Fitbit not do it???
Thank you
Hi, @NessieLR! Unfortunately, the Alta HR does not have any GPS connectivity.
MakMak | Community Council
Hi, @NessieLR! With some trackers (e.g., your Alta HR and pretty much any other model) you can have multiple trackers of different types on the account, but if you get another Alta HR, you will have to replace your current tracker. You can always add it back in later, if you want. Your data stay with the account, not with the tracker, so as long as you keep your same account and don't create a new one, you will be keeping your data. There is no way to turn off the Alta HR, if you don't want to keep it charged, you can just let the battery go flat.
