@SunsetRunner - by “pulsation,” do you mean heart rate? If yes, please make sure you are wearing it properly on your wrist. You may also want to make sure you are cleaning your Alta HR properly. Tap here for tips.
Best AnswerIt is not working. You say that i clean. I clean with cotton
How i can reboot?
Thanks
Best AnswerHi @SunsetRunner - here are the instructions for restarting your device. Hope it helps.
Instructions are from the Fitbit Help page.
