06-27-2020
12:23
19:01
06-27-2020
12:23
19:01
Alta hr will not turn on. I try charging it and it gets very hot.
06-28-2020 01:57
06-28-2020 01:57
Hi @LydiaMarie It sounds as if it might have died. Try restarting it a few times, but if that doesnt help, Customer Support is your only option.
Helen | Western Australia
07-01-2020 05:40
07-01-2020 05:40
Can I replace the battery on my Fitbit? I’ve tried recharging it different times and it will not sync. When I do try to sync, it gets very hot. If I can replace the battery, where can I purchase one ?
Lydia Marie
Best Answer07-01-2020 10:01
07-01-2020 10:01
Hi @LydiaMarie you can't replace the battery. While there are places selling the battery or offering the service to replace it, the cost would probably exceed the price of a new device. You might want to keep an eye out for sales. The Inspire series is the one which replaced the Alta series.
Best Answer07-01-2020 11:14
07-01-2020 11:14
