07-23-2016
16:54
18:17
07-23-2016
16:54
18:17
07-23-2016 16:57
07-23-2016 16:57
@Cupcakes249 Welcome to the forums.
You do need to have the charging cable in order to do a restart. Here are the directions - click
If you happen to be around a Best Buy, the Geek Squad often helps Fitbit users by letting them use the charger. Can't hurt to try.
07-23-2016 16:57
07-23-2016 16:57
07-23-2016 17:54
07-23-2016 17:54
Thank you for the advise. I will try stopping by Best Buy tomorrow.
03-04-2020 07:31
03-04-2020 07:31
My Alta is doing this daily now. There is plenty of charge on the battery and there seems to be no reason. I have to put it on the charger to restart. Very annoying that I can't factory reset it.
