06-08-2017
09:46
20:08
06-08-2017
09:46
20:08
Is anyone else as appalled as I am that Fitbit has chosen to not display the distance or mileage of a walk or a run when it shows the steps? Fitbit's response is that SmartTrack doesn't log this information. But it logs the number of steps and if Fitbit knows the number of steps, it knows the distance!!! Show it to us, Fitbit! Don't force customers to convert their steps to distance in order to get this information. If you choose not to log this critical information (I can't understand why) then at least do the conversion in the Activities page for the customer so we can see our mileage on runs and walks! It seems like such a simple fix.
06-08-2017 18:03
06-08-2017 18:03
@TPHikes I think it will show you the distance. On the app, go to your Account, then to Customize Display. From there you can select Distance. Good luck!
Best Answer06-09-2017 07:07
06-09-2017 07:07
Perhaps I wasn't as clear as I should have been. Distance is selected in my app, and I do see the distance on the day of the hike or run (3.1 miles this morning - yea!). My complaint is that I cannot see the distance or mileage of hikes or runs a day or more earlier. In other words, I want to see the history of my mileage. That is what's missing.
06-09-2017 09:28
06-09-2017 09:28
I can see past history of distance in my phone app. At the top of the dashboard, right under the step tracker, click on the distance tracker - it should display prior history in km/miles (depending on your settings). I hope this works for you, and that I haven't misunderstood again!
Best Answer06-09-2017 10:47
06-09-2017 10:47
Yes, I can see the past distance for prior DAYS as a total, but not prior HIKES/RUNS. My problem is located at the web login. In the dashboard there, on the left, is a box for "Recent Exercise". There, I can see this morning's Hike, which was automatically logged. When I click on that Hike, I see all sorts of helpful information, such as heart rate, heart rate zones, calories burned, number of steps taken, and number of active minutes – all for this particular activity, this morning's Hike. Yet nowhere to be found is the distance I went on or the mileage for this hike. This is why it is frustrating, because Fitbit is posting the number of steps taken, therefore it should be able to calculate the distance I went. But it doesn't.
06-10-2017 02:09
06-10-2017 02:09
I am having a similar issue. I went for a run the other day then synced my Fitbit to my phone. Exercise was automatically tracked as run and told me the time, calories burnt and average hr. However it didn't tell me the distance I ran. Then I worked out how to categorise exercise and when I changed it to 'sport' it told me the distance which I thought was strange as surely the distance should come up if exercise is catagorised as run. Went for another run today, synced again and tried to caragorise the exercise. When I clicked on 'run' 'walk' or 'sport' it didn't tell me the distance anywhere, just time, he and calories. I can find on the app and on my Fitbit info for my overall distance of the day but not for that specific exercise. Surely that should be a standard on the 'run' and 'walk' setting to tell you that's the distance you've run or walked?? Please help!
06-10-2017 07:21
06-10-2017 07:21
Here is a clear way to see the problem. When you drill down into a particular activity, you get a list that shows the distance as "N/A". Sorry, Fitbit but the DISTANCE IS APPLICABLE!!! PLEASE FIX THIS PROBLEM!
My Activity History for last two days
12-30-2017 06:26
12-30-2017 06:26
I agree with TPHikes, the lack of this feature is very annoying. I too would very much appreciate this being fixed.
12-30-2017 08:23
12-30-2017 08:23
@Nat17, @TPHikes, @kirsty280 and @JodiL -
Two things - don't just read the first thing and say "I already know that" and close the post.
The documentation states that MobileRun calculates distance, elevation, and pace for your walk, run, or hike. The steps, active minutes, and calories burned that you see on your Fitbit dashboard come from the tracker.
The documentation doesn't mention heart rate, probably because it isn't keyed for HR devices, but I can state that it samples your heart rate every second.
To save me a lot more typing please visit the post below. It discusses how I put MobileRun through the paces testing it and the results. I recommend reading all of the posts but definitely the one with the images of my activity records displayed.
Good luck and I hope this helps.
01-01-2018 03:58
01-01-2018 03:58
@TPHikes, @Nat17, @kirsty280, @JodiL I recommend voting for the feature request for SmartTrack to display distance for step based activities . The more votes, the more likely it is to be implemented.
01-01-2018 10:32
01-01-2018 10:32
@Julia_G -
Thanks for the link, both here and I believe another post. I didn't comment on the suggestion, but I did vote for it.
Best Answer03-05-2019 23:55
03-05-2019 23:55
I agree with @TPHikes that this is a basic requirement for any fitness tracker and it can be a simple fix. It really doesn't make sense that we have to carry a phone with an app (eg MobileRun, GPS tracker) to link to Fitbit to track distance when we are wearing tracker that is suppose to track our fitness activity such as running and walking just because the Fitbit tracker doesn't log in our distance.
06-08-2020 23:40
06-08-2020 23:40
This drives me nuts. I do Virtual Stride races and need to upload my data, and even though Fitbit tracks my miles, this chart doesn't show it! I NEED THIS TO SHOW!!!!!
08-09-2020 09:18
08-09-2020 09:18
Well only way iv figured out how to get my distance is to go to my exercise, tap on run then click the share icon and you will be able to see day and date. Exercise, caliories and finnally DISTANCE ....thank me later👍
Best Answer08-09-2020 09:30
08-09-2020 09:30
click on your exercise then click share icon in top right hand side corner then as seen above your distance becomes avalible to see ..
This is the only way iv found possiable to view my distance on my runs... if anyone knows of a better way please let me know
Best Answer08-09-2020 09:45
08-09-2020 09:45
@Jaff.mI don’t think that was a SmartTrack activity. I have tested your suggestion on both iOS and Android and SmartTrack activities do not show distance.
Did you track that activity by using your “Exercise Shortcuts”? That will give you distance, and you should not need to “share” in order to see it.
Best Answer10-17-2020 07:31
10-17-2020 07:31
I switched to an Apple watch and am so happy!
Best Answer01-16-2021 16:58
01-16-2021 16:58
My Fitbit does the steps nicely and when I have the gps on I get the distance. However when it shows up on my android phone the steps are correct but the distance is always way less than the Fitbit said at the end of the nordic ski. When you divide the steps into the distance I would have to only have an 8 inch step! What could cause this problem?
Best Answer08-05-2022 22:02
08-05-2022 22:02
I have the same issue as you!
Best Answer06-21-2023 10:19
06-21-2023 10:19
It registers the distance on the today tab but not in the exercise tab. I don't understand this either. But there is a tab in the exercise tab for distance.
