Wont sync
My Alta HR wont sync at all. I have tried everything from uninstalling and reinstalling the app to deleting my account and setting up a new one and still wont work. It will find my tracker and I put the 4 number code in and then it doesn't sync. Has anyone had this problem?? Were you able to fix it??
1 REPLY 1
Hi @CiaraSpencer
Have you tried restarting your fitbit?
I suggest restarting it at least three times, then restarting your phone and see if that works.
Also, please make sure you are far away from any other bluetooth devices.  I find that less interference makes the set up function much smoother and faster.
Please let us know if that was helpful, or if you need further assistance.
