04-11-2020
15:01
21:32
EstuardoFitbit
04-11-2020
15:01
21:32
EstuardoFitbit
Is there anyway to change settings to compensate for pushing a stroller. It only tracks a portion of total steps when I push a stroller.
It often has trouble detecting steps when the wrist is held steady pushing a stroller, shopping cart, or holding treadmill hand rail.
You can probably get a better step count putting the tracker in a pocket or somehow clipped to clothing. For some trackers, that loses heart rate but that's not an issue for the Alta.
Best AnswerIt often has trouble detecting steps when the wrist is held steady pushing a stroller, shopping cart, or holding treadmill hand rail.
Best AnswerGlad to hear that.
Make sure to wear a sock over it so it can't fall off and get lost.
