01-07-2017 12:11
01-07-2017 12:11
I have not been able to sync for 2 days now. Also, now none of my devices are picking it up on bluetooth. Alta is fully charged. I have uninstalled and installed the app. I have turned on location. Nothing is working...what now?
Best Answer01-07-2017 12:33
01-07-2017 12:33
Do you have WiFi enabled on your phone, @SherryLF? If so, disable it and try connecting. Also, make sure there is not another Bluetooth device active on the phone which would conflict with the Fitbit tracker - you might try turning off Bluetooth, wait about 15 seconds, and turning it back on.
Best Answer01-07-2017 14:51
01-07-2017 14:51
Mine isn't either husband tries it 2 his iphone works straight away it's starting to wind me up now I've done everything
