I am on my second Charge 3 after first one was deemed faulty. Now my 2nd one is showing as having no battery left on the fitbit screen when on the app and after a full nights charge it shows fully charged.
Not really sure which one to trust.
Best Answer@lancastriananda I thought you were sorted on this ?? are you still having problems? if you are give customer support a call they may be able to give you more options
customer support phone number will appear once the office is open (usually 0800 - 1900 Mon-Fri and 1000 - 1700 weekends in the UK)
This is for the UK but should you need to change country scroll to the bottom and look for United Kingdom with a down arrow next to it and click on the arrow now you can select your relevant country and the page will refresh
Kind Regards
Wayne
