Calories out in 'food' wrong
ANSWERED
There's always been an issue where the 'calories out = 775' in the food screen barchart isn't anywhere near the value shown in the 'today = 2366' values. (I don't have a screenshot for this). You can see the barchart for yesterday was low too.
What I have today is the calories in the 'energy burned' are correct, but both values in 'food' are wrong.
App is latest version, I've restarted phone (Samsung A54) and resynced (although it does have the correct values somewhere anyway 🙂 )
Screenshots below.
1 BEST ANSWER
Accepted Solutions
Hi everybody! Thank you for your messages and feedback as well as the pictures shared.
Our team is looking into this and will work on a solution afterwards.
Hopefully this gets solved soon.
I'll mark this post as best Answer so other users know that we are working on getting you all back on track.
Here the link (same as the one from our friend @Gr4ndp4 ) so that you all follow that thread where we will post all updates about this.
12 REPLIES 12
@martoff   I moved your post to the Android app forum, a better fit for this issue.
Laurie | Maryland
I'm noticing the same issue as of yesterday, 10/13/2025. Clearing the cache fixes it for that moment, but then the calories get stuck at whatever they were when I cleared the app cache. Hopefully Google is aware of this issue and working on a fix.
Yeah, that whole page is a bit broken when it comes the calories out value. Some areas it's ok some times, other areas different times! It's a pain as it's one of the main features of the watch I use.
Hi, @martoff@xlevix10, please review Calories out - Fitbit Community. I don't think your problem is precisely the same, but it might be related.
Please post here again & let us know how you get on.
Cheers
Gr4ndp4 | UK
Hi Gr4ndp4, yes a very similar issue. I've already reinstalled the app. and get the same problem.
Hi @Gr4ndp4, thanks for linking the post and offering the suggestions. I do see that you've escalated the bug, very grateful for that! Unfortunately for me, resetting the app only fixes the problem for a day, then it comes right back. Just like you, I noticed this issue after I upgraded to the Pixel Watch 4.
This problem began for me today (11/12/25). I have cleared the cache, force stopped, etc. To no avail.
@Lem5 , Thank you for your message and report. Our team is still looking into this.
Please keep an eye open for any Fitbit app update.
We will be releasing a new one in the next few days.
I cannot assure that the update will have a fix but at least it should improve the performance.
The only way I have found to get the numbers to match is to uninstall and reinstall the fitbit app on my phone.  I'm having to do this this daily.  It seems that part way through the day something stops the "cal out" figure syncing through to the main food tile.  In my case the "cal in" figure does still get updated and it does match the value in the food tile on the dashboard.
Mine worked for a couple of days and tonight it's incorrect again... calories outbin nutrition does not match what the dashboard or the watch says. I have tried the standard fixes. Nothing works. I'm about ready to give up totally.
Even that didn't work for me tonight.
