06-23-2016
09:44
07:16
RobertoME
06-23-2016
09:44
07:16
RobertoME
Battery level shows empty. What does this mean.
Moderator Edit: Subject for clarity.
06-23-2016 11:56
06-23-2016 11:56
you must fill it
08-01-2016 07:14
08-01-2016 07:14
Hi @axej, welcome aboard to our Community. Just as @SunsetRunner said before. When your battery levels shows is empty is notifying that you need to re-charge the tracker, otherwise you may find difficulties to sync or in the worst of the scenarios loose your data.
Let me know if you have more questions, I'll be around.
08-01-2016 08:09
08-01-2016 08:09
09-09-2016 04:39
09-09-2016 04:39
Hello @axej if you are having issues syncing your Flex with your Android phone try restarting your Flex by:
1.Plug your charging cable into the USB port and insert your tracker into the charging cable.
2.Insert a paperclip into the small pinhole on the back of the charger.
3.Press on the pinhole for 3-4 seconds.
Then restart your phone and try to sync as usual. If you are still experiencing issues after this you can find some troubleshooting tips on this post.
Let me know how it goes! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
