08-08-2017 23:32
08-08-2017 23:32
Hi,
I have had to change from the iPhone to the Samsung. My app is installed and connected but my dashboard isn't showing quite a few things, I don't have: steps, sleep, heart rate. I think that's all that I don't have. Can any one help me?
08-09-2017 09:29
08-09-2017 09:29
Try scrolling to the bottom of the dashboard on your phone, click on the red "Edit" button.
Find the tiles you are missing and click on the + sign to add the tiles (or - sign to get rid of them). Then click the red "Done" box at the bottom.
08-09-2017 10:24
08-09-2017 10:24
08-09-2017 10:24
08-09-2017 10:24
08-09-2017 11:00
08-09-2017 11:00
Those tiles should all be available on Android app also. I just searched and found some people solved similar problem by deleting, then reinstalling, app on phone. Just make sure you remember your ID (email) and password. Do a sync right before to make sure no data gets lost - sync will get all data to master database and be there with user name.
08-09-2017 11:46
08-09-2017 11:46
08-09-2017 11:46
08-09-2017 11:46
