11-18-2024 02:20
11-18-2024 02:20
Since latest update when I enter my weight it will not accept stones. From setting changed to kg that works. Set back to stones only option to input is pounds when entering new weight. Same on both android devices i use tried logging out and in, reset all devices too no change
01-24-2025 06:05
01-24-2025 06:05
Same here 🤔
Best Answer01-24-2025 06:53 - edited 01-24-2025 06:55
lizzy fitbit
what about the rest of it, the disappearance of the weekly averages for weight, one swipe / flick took you through the last couple of months, that was really useful, daily figures fluctuate, what about the lack of detail in the steps charts? used to break it down to 1/4 of an hour, now it's hourly, all the stuff I liked about fitbit is going, fix it or next time I'm looking for a smart watch I won't be looking at any of yours, keep downgrading everything like this and you're going to lose business, that's just how it works.
Best Answer01-24-2025 09:59
01-24-2025 09:59
@SunsetRunner and others. I just read an announcement that said this will be fixed with v 4.35 and that all users should get this by 28 Jan.
Laurie | Maryland
01-24-2025 10:17
01-24-2025 10:17
That.would be.great as I'm currently looking at the galaxy.watch.to purchase! Will hold off until January 28th now!
Best Answer01-24-2025 23:38
01-24-2025 23:38
01-25-2025 00:14
01-25-2025 00:14
Best Answer01-25-2025 00:30
01-25-2025 00:30
I just wanted to know if it had been fixed or was it just my app...
Best Answer01-26-2025 07:14
01-26-2025 07:14
Hi everyone.
Thanks for your continued reports. As I mentioned before, our team is progressively rolling out a new version of the Fitbit app which will include a fix for this issue. As with any other update, it's being released by phases so please check later and install it as soon as you see it available.
Your patience is appreciated and we'll keep working to make Fitbit more useful for you. Have a good one!
01-26-2025 08:03
01-26-2025 08:03
I had the update a few days ago. So all good. I use another app for fitness which had the same issue at the same time Fitbit but was corrected nearly 2 months ago.
01-26-2025 13:05
01-26-2025 13:05
Best Answer01-28-2025 01:58
01-28-2025 01:58
Just installed an update to 4.34.1 and still can only enter weight in lbs even though displays my weight in stones and lbs!
Where is fitbit's QA in this, you are losing non USA based clients if thus is not fixed very soon!
Cannot understand why this is taking so long, so many VERY unhappy customers.
01-28-2025 02:22
01-28-2025 02:22
Best Answer01-28-2025 02:42
01-28-2025 02:42
01-28-2025 02:47
01-28-2025 02:47
Hi could you explain how I do this please 🙏
Best Answer01-28-2025 04:24
01-28-2025 04:24
Best Answer01-28-2025 04:29
01-28-2025 04:29
Thank you, yes really frustrating 🤨
01-28-2025 05:37
01-28-2025 05:37
Hi everyone!
I'm happy to hear that some of you got the fix after updating the Fitbit app. For the ones that haven't done so, please keep checking the Play store and install the 4.35 version as soon as you see it available.
I understand the frustration caused by this situation, and appreciate your patience. Please know we'll keep working to improve your experience with Fitbit.
01-28-2025 07:53
01-28-2025 07:53
Just upgraded restarted phone brand new Samsung still exactly the same only accepts pounds, uk based not upgraded to google
Best Answer01-28-2025 08:03
01-28-2025 08:06
01-28-2025 08:06
If you open the app and press in progress does it not let you enter in stone and lbs?
