11-18-2024 02:20
11-18-2024 02:20
Since latest update when I enter my weight it will not accept stones. From setting changed to kg that works. Set back to stones only option to input is pounds when entering new weight. Same on both android devices i use tried logging out and in, reset all devices too no change
01-28-2025
12:53
17:48
EstuardoFitbit
01-28-2025
12:53
17:48
EstuardoFitbit
I updated and it worked fine, next day it was back to broke again. Update, it works, then the next day it doesn't. Do I have to update every time I want to use the thing?
Can you explain how you came to break it in the first place? And 4.35 it STILL not available in the play store in the UK, which is where the most users have a problem I suspect
01-28-2025 13:05
01-28-2025 13:05
Hi everyone!
@johndb123, @CathCasey and @FitbitUser0216 Thanks for keeping me posted. Please ensure that you have installed the Fitbit app version 4.35. This update includes a fix for the issue with weight entry not allowing stones. This update has been released for all our members. If you don't see it yet, check the Play Store later and install it as soon as it becomes available for you.
@EvilBillie That's great news! I'm glad the update worked for you and thanks for keeping me posted. Have a good one!
01-28-2025 13:12
01-28-2025 13:12
Hi,
Thanks update, mine was updated.on Jan 8th and still only registered as lbs.
It's so frustrating and time wasting to keep checking back for updates!
Do we have to wait for the update to become available?
Thank you!
01-28-2025 13:16
01-28-2025 13:16
Hi I have updated to 4.35 I went into weight settings and it let me change it to stone. I then went to enter my weight and it was still in lbs
01-28-2025 13:33
01-28-2025 13:33
Same!
I actually have my brother researching new smart.watches for me because this is so frustrating, paying for premium and not getting the service!
01-28-2025 15:06
01-28-2025 15:06
01-28-2025 22:22
01-28-2025 22:22
Hi Lizzy
Since your update my Fitbit app will now accept stones and pounds. However, I have to go to settings every time I log on and change settings to stones and pounds. Then when I close it, it defaults back to only pounds again. This is so annoying. Am I doing something wrong? Suzie
01-29-2025
01:05
06:03
MarioSFitbit
01-29-2025
01:05
06:03
MarioSFitbit
Exactly the same here we go again
No change still pounds or kg
Moderator edit - Merged messages
01-29-2025 12:19
01-29-2025 12:19
01-29-2025 12:26
01-29-2025 12:26
01-29-2025 12:27
01-29-2025 12:27
In fact this latest update has stopped the work around I was using of theh widget direct to the weight entry screen to get back to the old weight entry screen. I now need to hold down on the icon to get to it 😞
So they have just made it even worse not better!
01-29-2025 12:40
01-29-2025 12:40
Still no got yet either but my wife has received it. No idea how updates are rolled out by Google, who happens to own fitbit, but very frustrating that UK users being made to wait so long to get a working App. Feels like Google and Fitbit do not care about UK market to me
01-29-2025 23:45
01-29-2025 23:45
Hi - new version installed - only accepting lbs still
01-30-2025 00:03
01-30-2025 00:03
01-30-2025 00:31
01-30-2025 00:31
01-30-2025 00:43
01-30-2025 00:43
thanks - have checked they are clearly stones and the entry only still accepting lbs
01-31-2025 01:14
01-31-2025 01:14
Hi Mario how do I explain yo the community that since update it is still the same stones not recognised
01-31-2025 01:17
01-31-2025 01:17
Update now worked yesterday now again not recognising stones ans pounds, brand new updated samsung
01-31-2025 03:05
01-31-2025 03:05
01-31-2025 03:07
01-31-2025 03:07
