09-20-2016 21:08
09-20-2016 21:08
Best Answer09-28-2016 07:49
09-28-2016 07:49
Hello, @Rolix! Thanks for the updates! Yes, you can try to update with the computer by following these instructions:
If you cannot find the icon, you may need to reinstall Fitbit Connect fromhttp://www.fitbit.com/setup.
If this doesn't work, please get in contact with our Customer Support team, they will be able to further assist you.
Keep me posted! 😉
09-21-2016 06:22
09-21-2016 06:22
Hello there, @Rolix! It is nice to see you around. Are you still experiencing this issue? What do you see on the display?
If your tracker is stuck while updating, please finish the process using a different device or computer than the one you are using, if that doesn't work, you can try to restart it a few times in a row.
To restart it follow these instructions:
Let me know how it goes!
Best Answer09-21-2016 06:56
09-21-2016 06:56
i still receive the following message on my phone app for the second day:
"Fitbit Bluetooth service is busy, please try later."
Will try your method tomorrow and let you know the outcome.
Many thanks.
09-21-2016 19:30
09-21-2016 19:30
Followed your steps and tried to update the tracker but same problem and same error message.
Can I update with the dashboard in my computer instead of with the tracker?
Thanks for your help.
09-28-2016 07:49
Keep me posted! 😉
10-02-2016 06:06
10-02-2016 06:06
Dear Moderator,
Thanks for your detailed instructions, I have just updated to the latest firmware.
Best regards,
10-19-2016 07:23
