04-30-2020 12:45 - last edited on 07-30-2020 15:04 by LiliyaFitbit
Fitbit used to give exact running times when looking at map of a run. Now it rounds time up or down. How do I go back to exact times?
05-03-2020 09:33
05-03-2020 09:33
I have the same problem!!
05-05-2020 18:29
05-05-2020 18:29
Same here! For runners, rounded times aren't ideal.
05-26-2020 06:32
05-26-2020 06:32
Anybody have any update on this? I need to be able to see my exact time for a run rather than a rounded time.
05-27-2020 03:28
05-27-2020 03:28
Nothing heard yet which is quite disappointing. Fairly basic error which isn't difficult to fix, particularly as it works in Windows 10 but not in Android. Needs sorting now!
05-27-2020 04:34
05-27-2020 04:34
I've mailed them about this and they said they are looking into it. Bizarre that they have started to round the times. It wasn't the case up until recently. Surely having accurate times is one of the benefits of owning a fitbit.
06-09-2020 09:23
06-09-2020 09:23
I am finding this frustrating too. Trying to achieve run PB's yet I can't see what the final time is accurately enough.
07-13-2020 01:59
07-13-2020 01:59
Yeah. Im exactly the same as you. Im pushing myself to try and get a P.B time. Look at my watch and see my time. Then I sync it to the device and it rounds it. For example.. yesterdays run was 49.40 which was rounded up to 50 mins.
07-13-2020 02:06
07-13-2020 02:06
Hi m8. Im having same problem with the fitbit app. However what I discovered, (hopefully short term fix until app is updated) if you login to the Dashboard version of fitbit. It shows exact time.
07-13-2020 09:11
07-13-2020 09:11
Same here. Noticed that when I check the run I did it rounded up my time. My wife's versa showed on her Fitbit app on iOS exact time.
07-13-2020
14:35
11:58
RicardoFitbit
07-13-2020
14:35
11:58
RicardoFitbit
I ended up ditching Fitbit
Moderator Edit: Content removed - Promoting
07-24-2020 06:19
07-24-2020 06:19
Hello Fitbit team,
Is there an update to getting this working or changing the distance to be your exact time in a run instead of a rounded time like what iOS has?
07-24-2020 06:43
07-24-2020 06:43
Think they've given up on this one. Probably time to purchase elsewhere unfortunately.
07-25-2020 04:04
07-25-2020 04:04
Very disappointed with Fitbit for not resolving this simple issue caused by a Fitbit Android update. As a result this will be my last Fitbit before transferring to Garmin!
07-27-2020 06:36
07-27-2020 06:36
I'm trying to submit results for a virtual 5k today that I tracked with my Charge 4. Ridiculous that I couldn't get proof of an exact time in the app. Thank goodness the web dash board still had it but I really hope this error gets figured out soon.
07-30-2020 15:02
07-30-2020 15:02
Hello all, thank you for your participation in the forums and for reporting the issue with the running time being rounded in the app.
Your feedback and comments are greatly appreciated, I understand that this can be very frustrating.
I would like to advise that our team has recently released a new version of the Fitbit app. Please check if your Fitbit app is updated to the latest version as updates come with new features and bug fixes: How do I update the Fitbit app?
Let me know how it goes, I'll be around.
07-30-2020 15:17
07-30-2020 15:17
07-30-2020 15:19
07-30-2020 15:19
Hi thanks for reply. I have now updated the app and I will test out tommorrow after my run. Im assuming all old rund before update will still show as rounded times, or will theses be amended? Thank you.
07-31-2020 15:57
07-31-2020 15:57
Hi @Chazman1985, thank you for your reply.
I appreciate your efforts and will be looking for your reply after doing a test. I understand your concern regarding the previous runs, unfortunately the times for these runs won't be changed and will stay as shown. I appreciate your understanding.
Looking forward to hearing back from you.
08-03-2020 05:28 - last edited on 08-03-2020 16:41 by LiliyaFitbit
Can you tell me what the new version is please? My Fitbit android app
updated 3 days ago with version 3.26.1 (20243519) but I'm not seeing any
change. New times are still being rounded in Android on my two devices.
Thanks
