I can not view texts on my Blaze from Samsung note 8. I've enabled notifications on the Blaze as well as in the app. The text message indicator pops up, but doesnt allow me to view the message. My incoming call notification just started working today. I upgraded to a note 8 recently & it's never worked. Does anyone else have this issue? It says it's compatible on the Fitbit website, but it's not working.
Hello @Tanesha, good to see you again! You are right this phone is listed as compatible in our list of compatible devices. So in case you haven't try any troubleshooting steps at the moment, I would like to recommend the following post: My tracker isn't receiving notifications (Android Fitbit app).
You'll find there all the necessary help to address this issue. See you around!
Best AnswerI didn't mean to accept this solution because it didn't work. I can't read any text messages on my Blaze. I've tried to troubleshoot everything suggested.
Best AnswerDidn't work for me either. The only I get are phone calls. No text or emails and I have it set to receive notifications on the fit bit app
Best AnswerGo to notifications, then go to apps, select messages then make sure you have "show message on lock screen show content" clicked. After that your messages should show up.
