07-29-2015 19:37
07-29-2015 19:37
07-30-2015 16:41
07-30-2015 16:41
@nggThank you for sharing what worked for you. ![]()
Interested in seeing if this helps any other users experiencing the same syncing problems with Galaxy S4?
07-30-2015 20:20 - edited 07-30-2015 20:21
I have a Samsung Galaxy S4, I have tried everything, My phone app was not syncing with my tracker, could not find it, and would not work with resetting the fitbit one. I did it all, resetting phone, deleting app, reinstalling app, nothing worked till now. I installed BLE Checker app from the google play store, I then deleted it since it showed everything was ok. I then downloaded Bluetooth LE scanner, it found my fitbit one in seconds! Guess what, syncing is finally working with the app on my phone! HOORAY! Been driving me crazy for almost a week! THANK YOU VERY MUCH!!!!!!!
07-31-2015 07:02
07-31-2015 07:02
Best Answer07-31-2015 07:17 - edited 07-31-2015 07:31
Same issue since previous update last week. Never had a problem with my S4 until then. The update yesterday worked until I restarted my phone and now once again it cannot find details my tracker. Been through the whole uninstall etc processes. Tried this Bluetooth LE and yes fit bit now sees my tracker, says it's updating and goes through the motions but it doesn't actually update anything. I just wish I could turn the clock back a fortnight. I have now disabled updates and hopefully if they finally put it back to where it was I can keep it that way and ignore any more hit and miss untested updates.
Best Answer07-31-2015 07:35
07-31-2015 07:35
Best Answer07-31-2015 07:46
07-31-2015 07:46
Yes done all that and am on the same version of lolipop as yourself. Such a shame as it all worked perfect up until the update last week. I will give it another week for them to sort it out but for the time being its just a waste sitting in my pocket all day.
Best Answer07-31-2015 09:25
07-31-2015 09:25
Best Answer07-31-2015 09:38
07-31-2015 09:38
Yes i have tried this, all of which seems to give me temporary access to my Fitbit. I will get a sync then have to go through the rigmarole of restarting etc just to get another sync. Let’s face it we shouldn’t need to do all this and its only because fitbit released a bad update last week which has stopped many phones not just the S4. Sorry but if they can’t support their own product then people should be discouraged from purchasing. I just find it so annoying that it has worked perfectly since my purchase, well until their developers decided to destroy everything with shoddy work.
07-31-2015 12:56 - edited 07-31-2015 16:11
@JulitoHappy to hear that you had success with the suggestion by @ngg. Have you confirmed that your stats are transferring over to the online Dashboard at Fitbit.com also?
@Peter2873Have you updated to the latest Fitbit App for Android (2.8.2) which was recently released? If after trying the latest update you are still unable to sync, I suggest giving our Android Beta App a try. See ya around!
07-31-2015 13:40
07-31-2015 13:40
Yes i have tried the update and it allowed me one update before losing my tracker. I just wish I could go back to before the sleep update which has messed everything up. I have installed the Beta now and that finds the tracker, the sync symbol seems to spin for ever then stops. It updated my steps but removed my exercise. Haven’t got the patience for all these work arounds for something I paid good money for. I will just have to do without and wait and see if Fitbit get it working properly but certainly in the meantime I would certainly not recommend this product to anyone. I will be shopping around myself for a better product that is supported properly.
07-31-2015 16:22
07-31-2015 16:22
Best Answer08-03-2015 08:59
08-03-2015 08:59
Best Answer08-03-2015 09:13
08-03-2015 09:13
14:51
- last edited
Tuesday
08-04-2015
14:51
- last edited
Tuesday
@Peter2873I totally understand your frustration. As you've attempted all the troubleshooting steps I have suggested, I recommend you reach out to our Customer Support Team who can take a look into your account details to provide alternative troubleshooting steps.
@FergIt421Great to see you participating in the forums!
I'm sorry to hear of your bad experience but I am totally happy to hear that @ngg's workaround was able to resolve the issue you experienced! Thank you @nggfor the help!
@nggSince you mentioned that call notifications are not working, I highly recommend giving our Android call notifications beta a try! To sign up, check out this post here and follow the directions to get onboard!
Hope to continue hearing good results! ![]()
18:38
12:39
ErickFitbit
08-04-2015
18:38
12:39
ErickFitbit
Thank you thank you thank you! Finally a fix that worked. Thank you so much for posting!
Moderator edit: format
Best Answer08-05-2015 12:46
08-05-2015 12:46
Best Answer08-09-2015 12:09
08-09-2015 12:09
08-11-2015 11:16
08-11-2015 11:16
@nggKeep us posted if you do try the Android Beta App and what results you get!
Best Answer08-15-2015 19:09
08-15-2015 19:09
This worked for me! I have a Samsung Galaxy S4 and I tried to figure it out for 2 hours before finding this post! I'm so happy that my fitbit is now syncing with my cell phone.
Thank you so much for posting!!! 🙂
