Best AnswerThank you so much for helping me out. It's totally stumped by so-called techie husband.
The BLE scanner has its own checker, and it says "BLE enabled" when I tap "scan." Once I tap "connect," in the top right corner there appears a three-dot button that opens another button that says "disconnect."
This thread's pretty old, so I should say I'm using Fitbit version 2.11.1
One weird thing: I've connected it to the charger, then held the button until the fitbit logo appears, then disconnected the charging cable from the fitbit. This should reset the device, but I don't see any length of time when the thing seems to be turned off. Does that sound right?
@quyen_miHave you confirmed that you're running the latest version of the Fitbit App for Android? Additonally, I recommend confirming that you have the latest version of the firmware on your tracker. Also, have you confirmed that you meet the minimum requirements and have followed the troubleshooting tips outlined here? Hope this helps get you back on track! ![]()
@quyen_miI recommend following the troubleshooting tips outlined here. If that doesn't do the trick, I recommend reaching out to our Customer Support Team who can take a look into your device history and provide further troubleshooting tips. Hope this helps to get you back to stepping! ![]()
@DonniedjGreat news! Thanks for sharing the update! Happy to hear that you're back on track! ![]()
Best AnswerWOW, Thanks for this info.I have been having issues for a long time with my Flex, so bad I bought a Charge and had the same problem. I had to connect with the Bluetooth LE scanner a few times before it finally started working. My Charge is finally working! Thanks to all the Geeks out there who share their knowledge.
