03-12-2016
09:46
14:27
ErickFitbit
03-12-2016
09:46
14:27
ErickFitbit
My fitbit app wouldn't work with my new Samsung Galaxy S7 (Marshmellow) due to syncing issues. I just reset my fitbit (plug it into laptop/wall charger and hold button on left side for approx 10seconds until fitbit symbol appears, then unplug it). App worked instantly! 🙂
Moderator edit: edited title for clarity
04-05-2016 14:20 - edited 04-05-2016 15:22
@StephWilton@shannbil@JMor925@whitneysmith@Emil85 The Galaxy S7/S7Edge is not currently listed as a supported device. I recommend following the same steps that I suggested regarding the Galaxy Note 5 here. It doesn't hurt to try set up but it isn't guaranteed that all features will fully function with a device that is not listed as supported here.
@JMor925@whitneysmith@Emil85 No ETA on when these devices will be listed as fully compatible with the Fitbit app for Android as our engineers have to test all features before adding it. I recommend keeping an eye on this page, as it will be listed there when fully supported.
04-05-2016 15:01
04-05-2016 15:01
04-05-2016 15:23
04-05-2016 15:23
@ldock1412 I moved your post into this thread as it is relevant to the S7/S7 Edge. Check out my response here.
04-13-2016 17:23
04-13-2016 17:23
04-13-2016 17:27
04-13-2016 17:27
04-18-2016 11:36
04-18-2016 11:36
I was able to get my surge to receive the notifications from my Samsung S7 Edge. At first I was having problems receiving notifications at all so I first changed the text notifications in the Fitbit Application settings to point to Message+ (Verizon messages). After syncing my phone I was receiving notifications on my surge but it would not allow me to view the message. I then went to the Fitbit App and changed my text notifications to point to Messages, then went to my S7 edge and changed my default txt messages to Samsung Messages (the yellow txt msgs icon).
04-20-2016 04:19
04-20-2016 04:19
04-20-2016 06:52
04-20-2016 06:52
04-20-2016 23:40
04-20-2016 23:40
04-21-2016 05:00
04-21-2016 05:00
04-21-2016 06:19
04-21-2016 06:19
04-21-2016 06:28
04-21-2016 06:28
which fitbit do you have? Is it the Surge? If it's the Surge, go into the Menu->Settings->and scroll down to Shutdown
04-21-2016 08:16
04-21-2016 08:16
04-21-2016 08:31
04-21-2016 08:31
not sure if this will help but try this: https://help.fitbit.com/articles/en_US/Help_article/Why-can-t-I-set-up-my-new-tracker-using-the-Fitb...
04-23-2016 01:35 - edited 04-25-2016 00:48
@rmadison75 wrote:not sure if this will help but try this: https://help.fitbit.com/articles/en_US/Help_article/Why-can-t-I-set-up-my-new-tracker-using-the-Fitb...
No, still have problem on Galaxy S7 Edge with Android 6.0
05-05-2016 16:51
05-05-2016 16:51
any udpate on when fitbit charge HR will be compatible with galaxy s7? My phone wont see the fitbit at all and unfortunately I cannot synch with my new IpadPro since it's not compatible nor my laptop running windows 8 since fitbit just stopped supporting windows 8. I'm literally stuck
05-16-2016 20:19
05-16-2016 20:19
So basically, I need to return my FitBit Blaze? I brought the S7 and Fibit Blaze today. If I cannot receive notifications or adjust my music, then what is the point of having the Blaze? I might as well use only Samsung products. Do you all plan to do a mass update once testing is done? Or will you come out wihth a Blaze 2?
05-21-2016 12:08
05-21-2016 12:08
05-22-2016 17:58
05-22-2016 17:58
05-23-2016 05:49
05-23-2016 05:49
Welcome to the Forums @DrJoshFromBama @Darnjimmy! You should take a look to @ErickFitbit's suggestion in this post. It contains the response to your inquries.
Let us know how it goes.
