03-12-2016
09:46
14:27
ErickFitbit
03-12-2016
09:46
14:27
ErickFitbit
My fitbit app wouldn't work with my new Samsung Galaxy S7 (Marshmellow) due to syncing issues. I just reset my fitbit (plug it into laptop/wall charger and hold button on left side for approx 10seconds until fitbit symbol appears, then unplug it). App worked instantly! 🙂
Moderator edit: edited title for clarity
How did you resolve the issue? I have tried restarting the fitbit, reinstalling Fitbit, restarting the s7. Is fitbit still not compatible with the Samsung 7?
Best AnswerThe Blaze works perfectly with the s7, the Versa DOES NOT. So annoying. Going to try Garmin
Best AnswerHave you checked Garmin to make sure your phone works with their tracker, not all phones do.
