05-15-2016 19:05
05-15-2016 19:05
I have an LG G3 adn I can not get my text notifications to come to my Blaze. I have tried all the tips, Ive tried installing Bittracker. No luck. I am getting call notifications, but no text. Any ideas?
Best Answer05-16-2016 07:08
05-16-2016 07:08
I was able to solve the problem by downlaoding another application to push notifications.
Best Answer05-16-2016 06:52
05-16-2016 06:52
A warm welcome to the Community @nean147. If your Blaze is not receiving your notifications, I recommend following the tips that @MarreFitbit is providing in the My tracker isn't receiving notifications thread.
I hope this helps, let me know the outcome. ![]()
05-16-2016 07:08
05-16-2016 07:08
Best Answer05-16-2016 07:15
05-16-2016 07:15
Great to hear that your tracker is now receiving notifications @nean147 and thanks for sharing the tip. If you need anything else, do not hesitate in posting it. ![]()
See you around! ![]()
Best Answer07-29-2016 15:49
07-29-2016 15:49
Best Answer07-30-2016 04:01 - edited 07-30-2016 04:02
The app is called bitTicker Notifications. It is actually pretty awesome because you can also push Facebook messages to your Blaze with it.
Best Answer01-19-2017 05:02
01-19-2017 05:02
I have galaxyS6 can't get text messages over my alta
Best Answer01-19-2017 05:04
01-19-2017 05:04
It's great to welcome you @Bradway48. If your tracker is not receiving notifications, I recommend following @MarreFitbit's instructions in the My tracker isn't receiving notifications (Android Fitbit app) post.
I hope this helps, let me know how it goes. ![]()
