07-21-2021
08:35
16:45
SilviaFitbit
07-21-2021
08:35
16:45
SilviaFitbit
My versa 2 will not work with my Huawei P smart phone.
I have tried repeatedly to get it to Sync.I spent £147 on buying the new Versa so I am not very pleased about it.
Any suggestions please
Best Answer07-21-2021 10:06
07-21-2021 10:06
Hello @SunsetRunner and welcome to the Help forum. There are several phones in the "P" series. Two of them are incompatible with the Fitbit app. One requires specific settings. Compatible devices Which phone do you have?
I am moving your post to the Android forum in hopes that you might get more help. You can also browse the Android forum using your phone model to see if there is an answer.
Laurie | Maryland
07-21-2021 13:43
07-21-2021 13:43
many ,many thanks.
I will check and see which model I have
Regards,
