11-29-2019 18:22
11-29-2019 18:22
My Versa 2 will not reconnect to my Samsung Galaxy s10e. I had disconnected the bluetooth because it was no longer showing me notifications and was not syncing to my app. I've tried restarting my phone and the app nothing has worked.
12-01-2019
09:49
03:55
12-01-2019
09:49
03:55
@Sorrie Welcome! Thanks for being part of our Community! Sorry for the delay in my reply.
Let me help you with your Versa 2 not syncing with your phone and thank you so much for troubleshooting this issue. Lets try refreshing the link between your phone and your tracker by doing the following:
Let me know how it goes.
Best Answer01-01-2020 11:12
01-01-2020 11:12
Is fitbit working to fix these issues or should I return and purchase a different brand of fitness watch?
01-30-2020 19:59
01-30-2020 19:59
Mine is doing the same thing. I am very upset
02-05-2020 15:10
02-05-2020 15:10
I'm having the same problem. Samsung 10+ and new versa 2.
02-05-2020 15:21
02-05-2020 15:21
I got it fixed. So what you have to do is unpair your fitbit 2.... turn your bluetooth off...restart your phone..turn it back on....go to the fitbit app and log out...then log back in and repair your fitbit...also restarting you fitbit 2 by holding in the button until the screen turns black...do this after you unpair it to your phone...let me know if that helps
02-29-2020 17:44
02-29-2020 17:44
This has been happening to me too. I finally figured out that, in my case, the Versa had connected to my iPad. It seems it can only connect to one device at a time. When I shut off bluetooth on the iPad, it then connects successfully to my phone. Guess I need to just unpair the Versa from the iPad and see if the problem actually goes away.
06-15-2020
19:34
11:32
RicardoFitbit
06-15-2020
19:34
11:32
RicardoFitbit
Try to unpair the phone in the app. When you repair it choose Versa not Versa 2, even though it is a Versa 2. Just say here for 2 hours trying everything under the sun. My last ditch effort i chose the Versa instead of the Versa 2 in the selection. It connected right away. My fit bit is a Versa 2
Moderator Edit: Formatting
07-16-2020 04:39
07-16-2020 04:39
I'm having the exact same issue, Samsung S10+, Connect pair manually to bluetooth, cannot pair through the app - restarted everything, plugged it into my computer, everything. Nothing responds.
Kinds of worrying really.
07-25-2020 10:32
07-25-2020 10:32
That doesn't work all the time. Shouldn't have to do so many steps every time you need to sync.
08-11-2020 21:46
08-11-2020 21:46
I'm having the same trouble. Upgraded my phone to Samsung S10 and one week in my Versa 2 won't connect. Ive uninstalled the app, restarted my phone, tried everything. Really not impressed 😏
Best Answer08-12-2020 00:32
08-12-2020 00:32
Go to settings on fitbit reset ro factory. Then go to the app to set a new devise. Even though your devise is register, fo ahead and said" change device.
Took me 5 hour to figured it out.
08-12-2020 23:25
08-12-2020 23:25
Thanks for your reply, my phone also won't pick up Bluetooth to connect to the watch.
Best Answer08-24-2020 15:27
08-24-2020 15:27
Thank you Tiredon!
I had tried for hours to reconnect my versa 2 but failed. Redoing it as a Versa is succeeding! Thank you so much for the hint.
Best Answer08-24-2020 15:32
08-24-2020 15:32
Best Answer08-29-2020 10:04
08-29-2020 10:04
Following these directions worked. On 8/25/20 my Versa 2 stopped connecting and was not recognized over Bluetooth by my Samsung Galaxy S7. Now (8/29) after following the directions, the Fitbit app on my phone is downloading data and synchronizing time with the Versa 2. But an odd situation, the Bluetooth feature of my phone is not recognizing (or reporting a pairing of) the Versa 2.
09-04-2020 07:30
09-04-2020 07:30
When I try to connect my fitbit versa 2 by Bluetooth to my phone it says an app is needed to use this device
What do I do? I've unpaired it, turned bluetooth off and on, turned my phone off and one, ans reset my fitbit and nothing...
Best Answer09-04-2020 15:57
09-04-2020 15:57
Best Answer09-24-2020 19:34
09-24-2020 19:34
No real answers here. My phone is not even recognizing my fitbit thru Bluetooth anymore. This isn't a new device I've had it for years with no issues, get the new update and now poof it's not working at all. Before I selected "forget pairing" in my Bluetooth settings my Bluetooth kept saying that an app was needed to connect my fitibt. Obviously I have the app. And now that I've unpaired my device it's not even visible. This problem needs fixed!
09-28-2020 16:52
09-28-2020 16:52
I'm having the same issue. mine stopped working on the 24th
