02-05-2019
12:56
08:59
AlvaroFitbit
02-05-2019
12:56
08:59
AlvaroFitbit
When will Huawei p smart be compatible with Fitbit versa
02-06-2019 10:33
02-06-2019 10:33
@Nikki71 Welcome! It's good that the community is growing! Thank you for your inquiry. There is no official timeline for this implementation. Still if your phone isn't listed as compatible that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
11-16-2019 02:58
11-16-2019 02:58
It never sinks
